Excessive brake dust 1 side
nolig2278
Post by nolig2278 »
my driver side wheel rim has noticeably more dust than the passenger front after one day of driving. i have not worked on the brakes for at least 6 months.
i do hear a little noise while driving and braking but there is no pulling while driving. Some pulling during high speed driving, but could be alignment.
what can I look for? outer pads seem to be fine. Gas mileage is same as it has been for a long time.
thanks
94 RS to BPT
2.5 FMIC
MicroSquirt
2.5 Exhaust
[url=https://gilon.levinsonltd.com/mx-3.html[/url]
ariesdude
Post by ariesdude »
maybe a warped rotor?
94 Mx-3 Precidia
nolig2278
Post by nolig2278 »
they r slotted and drilled rotors and not too old, never resurfaced so they shouldnt be warped, also no vibration
94 RS to BPT
2.5 FMIC
MicroSquirt
2.5 Exhaust
neutral
Post by neutral »
Make sure both sides have the brake pad return springs in place. Forget the exact name (maybe "K" springs). Has the caliper slide h/w been cleaned and lubed when the latest pads were installed? Might have a caliper hanging up a bit. Is the pad wear even on both wheels when comparing outbd-to-outbd and inbd-to-inbd pads from each wheel?
Image -Jim
nolig2278
Post by nolig2278 »
i will try to check things out tomorrow.
thanks
94 RS to BPT
2.5 FMIC
MicroSquirt
2.5 Exhaust
ryan_Fuerte
Post by ryan_Fuerte »
yah check out the caliper sliders, these style of front brakes tend to seize up. Pull out the slider, and rubber , and put lots of slide glyde(brake lube) on them
Mx-3 GSr : Rebuilt klde with 5spd swap, xtd stage 3 clutch, Magnaflow dual exhaust,Accord custom intake, kyb gr2 struts with eibach springs, civic dual halo projectors, black altezzas, white 15'' oz rims, rolling on dunlop street slicks.
http://www.cardomain.com/ride/2400330
lutos
Post by lutos »
also make sure your caliper isn't stickin on or siezed and make sure your pads slide in there holders, if not clean the holder with a file until its clean lube and put the pads back in
nolig2278
Post by nolig2278 »
this is the caliper that i purchased from pepboys in february 06. it is rebuilt. would it be likely to have the slides jamming already?
they are a pain to get in and out
94 RS to BPT
2.5 FMIC
MicroSquirt
2.5 Exhaust
ryan_Fuerte
it doesnt matter if its new or 5 years old, if you installed it, did you lubricate the sliders? all it takes is a bit of rust and the caliper goes from a free floating caliper to one thats is stiff and wont slide.
Nothing is wrong with the caliper, if its that new,
