something you should never do
- slimsmedley
just thought i should pass on to everyone that you really shouldn't turn your car on while its in gear and parked in front of a brick wall, even with the handbrake on tight.
$5500AU for respraying, bodywork, radiator, air conditioner core, new headlights+foglights+bulbs, badge, number plate
$500AU for new wall
don't try this at home....
$500AU for new wall
1994 Eunos 30x Sports
blaze red, Jap KL-DE 2.5 V6 conversion, KL28 ecu, Auto to Manual gearbox conversion, lightened flywheel, Top Gun leads, aftermarket radiator, Elf engine oil and filters, 2 1/4" cat-back mandrel bent exhaust with carbon fibre/stainless steel muffler and 4" tip, Pioneer sound system, 17" SSW rims, 101.3 wheel k/watts @ 6500rpm
- Tropical Emerald 1993
Faulty clutch switch? the car shouldnt even start when the clutch is not pressed. Remote starter alarm?
-hec
- slimsmedley
must be the clutch switch, because i tried starting it again without pressing the clutch while in gear and it fires up just like normal. difficult to repair?
I dont think so, just replace it. Its not an auto to manual swap is it? its unsafe to have it that way. I did have my maxima that used to be auto and converted to manual. I have the having of pressing the clutch to start it.
-hec
- mr1in6billion
Unclip, clip in new one. That simple. (It's the one behind the pedal, if your wondering). You should check it before getting a new one. It should show continuity when you press it, nothing when you don't.slimsmedley wrote:must be the clutch switch, because i tried starting it again without pressing the clutch while in gear and it fires up just like normal. difficult to repair?
- slimsmedley
i will have to give mazda a buzz to find out if its supposed to have a switch, i don't really know what i'm looking for... But if anyone knows if the AU Eunos has one or not, that would be helpful
- tehbrookzorz
