BPT swap into a 4cyl?
Hey guys, just wondering if it would be a direct drop in or not... a BPT for my 1.6l 4cyl? or should i be looking at a different engine? thanks.
- atlantamx3
Do any of these new guys even use the Search feature on this forum? ![Rolling Eyes :roll:](./images/smilies/icon_rolleyes.gif)
JSpec Turbo MX3 (1.6 DOHC)
http://www.cardomain.com/memberpage/310985
Port and Polished Head, Ported Intake Manifold, Valve Job, GTX Manifold, Hybrid Turbo, Cone Filter, 2.5" Exhaust, 2.5" Downpipe, ACT Street Clutch, Lightened Flywheel, MSD 6A Ignition, Boost Retard and SS Coil, Magnecor Plug Wires, Denso Iridium Plugs, UR Lightened Pulley, Spearco FMIC, Turbo XS BOV & MBC, BEGI RRFPR, Supra Injectors, Walbro 255 Fuel Pump, Autometer Gauges, Pivot Shift Light
Don't look for info in regards to the '95 RS, look for info in relation to the B6 DOHC 1.6 and swapping to a BP/BPT swap. 92-93 has the 88hp SOHC, 94+ have the 105hp DOHC. However, the 92-93 SOHC have the benefit of having a wiring harness that, for what i've read, plug-n-play with the BP's. the DOHC harness requires splicing, or you swap to a SOHC/BP harness. As for fitament, it physically fits in like stock, the complexity is the wiring harness.
The reason why you can't find any specifics to a 95 cause there is no diff (that i'm aware of) between the RS from 94 to end-of-production. They all use the DOHC in those years.
