B6T to B6ZE head swap
Posted: March 1st, 2007, 10:10 pm
by Campbell*
Ok first of Iv search and couldn't find any threads that contained info to the b6ze head swap. If there was thread Im sorry but I need to know
I bought a complete B6T swap but I don't want to run a hood scoop and wouldn't mind the extra ponies that come with he N/A head. I hear I can put the b6ze head (I think thats what the N/A DOHC head is called), but I need to plug two oil galleries or somthing in the front. Is their anything else that I need to do to make the head fit the B6T block? Also, what cams do I use, the turbo cams or the N/A?
If you have any info that would be great because Im doing the head swap very shortly.
Posted: March 1st, 2007, 11:08 pm
by 95 rs
you have to plug the front oil galleries on the head. then there is another gallery that you have to plug. its near the transmission on the block.
use the n/a cams as the b6t cams WILL NOT work. the duration of the cams is off and it will just be easier to use the n/a cams as they are made for the head. thats all i can remember for now but ill try to remember other stuff and feel free to ask questions since i tried this before.
Posted: March 2nd, 2007, 3:53 pm
by monty73741
I think jarid did that swap...u can always use the turbo parts & put them on the b6ze
jason
Posted: March 2nd, 2007, 4:04 pm
by Tunes67
I think the B6ZE head (engine) came only as a RWD application (Miata) and the DOHC B6DE is what came stock in the 94+ MX-3's. They will bolt onto the block.. but the intake & exaust manifolds are on opposit sides I think.. Or maybe it was an issue with the distributor location.. I am not certain in any case.. but I think there are issues with the B6ZE head. I bet Josh would know for certain. But you should be able to swap to a B6DE head without a problem. Cheers
Tunes67
Posted: March 3rd, 2007, 4:35 pm
by cjthor
monty73741 wrote:I think jarid did that swap...u can always use the turbo parts & put them on the b6ze
jason
I used the stock head. I wasnt aware of any gallys that had to be plugged. I got custom cams and used the b6t block and rods...and used my stock crankshaft and weisco pistons.
Posted: March 3rd, 2007, 4:54 pm
by TREVO123
Why dont you just swap the intake mani's? Be much easyer if u ask me.
Posted: March 4th, 2007, 1:18 am
by monty73741
TREVO123 wrote:Why dont you just swap the intake mani's? Be much easyer if u ask me.
i think u cant swap the intake manifold
Posted: March 4th, 2007, 10:27 pm
by Campbell*
nope, no intake mani will work with out modification so Im just going to do the head swap.
what should I use to plug the oil galleries?
Posted: March 5th, 2007, 2:48 pm
by cjthor
Campbell* wrote:nope, no intake mani will work with out modification so Im just going to do the head swap.
plugs. like threaded plugs.. Although I dont think you need to. I will check with the guys that did my swap.
Posted: March 6th, 2007, 1:50 am
by monty73741
so the b6ze intake manifold will work on the b6t head
jason
Posted: March 6th, 2007, 3:09 pm
by Campbell*
no, the b6ze manifold wont work on the b6t head
Posted: March 7th, 2007, 9:38 pm
by Campbell*
This may be a stupid question but where do I get these threaded plugs, the head should be here anyday now and I have all the other parts except the plugs.
