Cel light newb
- Tropical Emerald 1993
Cel light newb
If anyone can refer me to section in manual or answer this about cel codes:
1. There are two GNDs. does it matter wich one I use?
2. When I jumped TEN and GND cel didn't go away or blink. It just stayed on along with oil and light.
http://www.mx-3.com/phpbb2/viewtopic.ph ... nostic+box
sure is a good thing i looks this up. I just relized i've been using the other GND haha. Oops. Thats the diagram for ya. Turn the key to on, and watch it flash. If it does flash, there are no codes.
If your not getting anything, and your CEL comes on, Take of your neg batterie cable, hold the brake for 20 seconds, then put it back on. That will clear your ecu. Now, go for a drive around or let it run for while. Then check for codes.
I did that but all lights are still on (battery, oil and light). Maybe this doesn't work with sohcVanished wrote:If your not getting anything, and your CEL comes on, Take of your neg batterie cable, hold the brake for 20 seconds, then put it back on. That will clear your ecu. Now, go for a drive around or let it run for while. Then check for codes.
European cars may not have CEL functionatilty - you can use a test light between FEN and B+ to mimic CEL
94 Mx-3 Precidia
test light -> FEN & B+
jumper -> TEN & GND
turn ignition on - but dont start the engine. If there are any codes the test light should flash - if not it will turn on briefly and go off i think.
jumper -> TEN & GND
94 Mx-3 Precidia
ariesdude wrote:European cars may not have CEL functionatilty - you can use a test light between FEN and B+ to mimic CEL
94 Mx-3 Precidia
WTF????Tropical Emerald 1993 wrote:so can I just put bulb between FEN and B+ or do I need special equipment?
http://en.wikipedia.org/wiki/Test_lightariesdude wrote:test light -> FEN & B+
jumper -> TEN & GND
94 Mx-3 Precidia
