is there a chip or any other gauraneed powergains for the v6
have an decat, exhaust and cold air induction but dont know what other options are open
cheers
also my engine is the non turbo version, shame lol
chip
DON'T GET A "PIGGY-BACK" "CHIP"
Plug wires and plugs are simple eazy to find and cheap
6-2-1 headers arn't hard to find for the probe if you are tricky enough to remanufacture your lower transmember.(or rich enough to custom make MX-3 headers)
Upgrade your suspension (it is a FWD sports car)
underdrive pullies are cheap and eazy to install
Jet chips are cool but you have to go without your car for a day or so
cam shafts are expensive and more advanced to install
larger throtle body
Electric super charger (more than 400cfms)
larger throtle body
2.5 KLZE, Mazda speed after market cams, 6-2-1 Headers, high flow cat, ram air cold steel mesh air intake, TAMS, ECM, 10.2mm NGK, Bosh +4s, KYB struts, Bomz coilovers, Interstate 750 cca battery, Exedy 22spline clutch and p-plate, Det-Mar electric supercharger.
NO PAINT OR RIMS... DONATIONS PLEASE.
- kiwi_MX3
- Location: Backpacking in Canada in vancouver 13march onwards
Decent plugs and wires are only good if your running HEI systemjdallis33026 wrote:DON'T GET A "PIGGY-BACK" "CHIP"
larger throtle body
MX6-Probe headers fit just need to shorten the cat back part.
Cam shafts are a waste of time on the stock ECU reset the stocks
to 90 degrees centers and you gain power.
Boring out the throttle body is so so i don't see the point in it on
the stock intake system.
My engine suck's well in excess of 400cfm so those are a waste of time.
- ryan_Fuerte
Are you kidding me?? you actuall experienced a gain from an electric supercharger. Or are you talking about the ones that need like 6 car batterys to run it . Even those only give like 2psi of boost dont they.
-Ryan
Mx-3 GSr : Rebuilt klde with 5spd swap, xtd stage 3 clutch, Magnaflow dual exhaust,Accord custom intake, kyb gr2 struts with eibach springs, civic dual halo projectors, black altezzas, white 15'' oz rims, rolling on dunlop street slicks.
http://www.cardomain.com/ride/2400330
- PWRD_BY_HKS
ryan_Fuerte wrote:Electric super charger (more than 400cfms)
-Ryan
.....YEAH.... good question... and the QUESTION AT ONCE!!!!! this had been a questioned many upon many times.... you might have the answer....
jdmx-3 KID OF THE ![Image](http://img118.imageshack.us/img118/8885/3kidkn5.jpg)
VICTORIA RACING
ZE PERFORMANCE IN 915 TX
Kl01-ZE,Kl31 ecu, millenia manifold, ngk plugs, ngk wires, probe tranny/ and clutch (stock), VortecH FMU 12:1, Aeromotive AFPR, Tial .38mm Wastegate w/ 4lbs spring, Walboro 255 pump, AiResearch T4, 3" down pipe, GODSPEED manifold, Spearco Boost Gauges, BF Goodrich G-force drag radials.
14.8 1/4 mile all motor untimed on boost.
VICTORIA RACING
- ryan_Fuerte
Hahah yah you look at the thomas knight electric supercharges, they make them sound so good, but they only flow like 450cfm and make 5psi boost. and your paying 1650US for the kit, and i believe that it is a universal kit. It be intresting to actual see one of these in use on an mx3.
-Ryan
-Ryan
- PWRD_BY_HKS
dude 5 psi.... that is still pretty not too bad.... sounds cool huh.... any way.... yeah i have always wondered if they really work of it that "TWISTER" of "TORNADO" what ever thing works....
VICTORIA RACING
VICTORIA RACING
