what size are the klze injectors?
mab
Post by mab »
could not find it under facts
Nothing like an mx3 project car
Slammed6
Post by Slammed6 »
KL - 220cc :D
K8 - 180cc
mab
Post by mab »
thank you
ryan_Fuerte
Post by ryan_Fuerte »
yah klze injectors are the same as the ones found in the klde engines, probes and mx6's. They should have a blue top on the injector.
Mx-3 GSr : Rebuilt klde with 5spd swap, xtd stage 3 clutch, Magnaflow dual exhaust,Accord custom intake, kyb gr2 struts with eibach springs, civic dual halo projectors, black altezzas, white 15'' oz rims, rolling on dunlop street slicks.
http://www.cardomain.com/ride/2400330
maryus
Re: what size are the klze injectors?
Post by maryus »
KF ? 220cc will go ?
HKS or GREDDY ?or whats good thx.
EDIT: dont worry i found out , KFZE-KLDE-KLZE all use same injectors size, 220cc. and blue tops ok .
'92 Black Mazda Mx-3 - kl-ze
93MX3KLZE-T
Post by 93MX3KLZE-T »
The millenia s injectors are 280 cc and fit in our rails.
93 MX-3 GS, KL-ZE, T304E ***SOLD***
221.9 whp 219.0 wtq @ 5 psi untuned
13.4 @ 108 mph
maryus
Post by maryus »
and that means it will run more rich ? 280cc vs 220cc , first will give more fuel right ? but its more power
Trevor
Post by Trevor »
I's only more power if you put more air in with the extra fuel
RX8SE3P
Post by RX8SE3P »
Bumping this thread, I just got my injectors cleaned and tested at a shop.
The report says each injector scored about 48-49 for Wide Open Test for 15 seconds. Then next to that, it says x4 for CC/ min.
So that equates to about 190-200CC for each injector. A little bit off the 220CC mark. Are these injectors ok, they reported no leaks and are all within good specs of each other. Spray pattern is also good.
Does anyone else have any injector reports they can post up? I might be able to post a pic of the report later.
1995 Eunos 30x KLZE
