Problem with bolts where hatch visor once was...
Recently there was a snow storm that occured and it actually cracked my hatch shade visor right down the middle. I took it off as it was breaking off anyways. Any way, there are now ugly rusting bolt that stuck there and i can't get them out. Any one out there that can help me?
The only suggestion I can come up with right off is something you've probably already considered.. find a replacment shade
Otherwise you might see if you can somewhere find Mounting instructions for the shade, you could then reverse the process, to dismount the bolts.. Could be that there's a piece of trim that was replaced by the shade, that would need to be obtained to cover the holes.
