Help.
It was sunny here yesterday and stupid me decided to use gunk to clean the engine and sprayed it off as usual. Only this time after the wash the engine was running very rough.
I managed to drive around the block hoping it will clear itself but it did'nt.
It was running like a bag of s---!
I tried starting it today and it won't even start!
It cranks but won't start.
Help.
Help car won't start no more after wash!!
- lowridah313
check to make sure that theres no water in the spark plug tubes.
Representin' the THRE3:TH1RT3EN
'02 Nissan Xterra SE, atx, 4x4, 32's
'92 Geo Tracker atx, 4x4
Feedback http://mx-3.com/phpBB3/viewtopic.php?f= ... 54&start=0" onclick="window.open(this.href);return false;
- PWRD_BY_HKS
blow the engine out with a compresor ...i second the plug tubes
jdmx-3 KID OF THE ![Image](http://img118.imageshack.us/img118/8885/3kidkn5.jpg)
VICTORIA RACING
ZE PERFORMANCE IN 915 TX
Kl01-ZE,Kl31 ecu, millenia manifold, ngk plugs, ngk wires, probe tranny/ and clutch (stock), VortecH FMU 12:1, Aeromotive AFPR, Tial .38mm Wastegate w/ 4lbs spring, Walboro 255 pump, AiResearch T4, 3" down pipe, GODSPEED manifold, Spearco Boost Gauges, BF Goodrich G-force drag radials.
14.8 1/4 mile all motor untimed on boost.
VICTORIA RACING
wet ignition system.. its not just spraying the car when you wash it.. you gotta cover the disty :S
-hec
