megan springs, to low?
kellywellz
Post by kellywellz »
I have a set of megan springs there suppose to lower my car 2 inches in the front and 1.75 in the back, i have 17's do u think it will be to low???
blue 92 mx3,95 bp swap, 97 kia tranny, spec stage 1 clutch,white excel rims.
Vanished
Post by Vanished »
Ok.
I don't understand this. Why do peopel keep asking this? If your overall TIRE diameter on the OUTisde is the same as stock (aka, you got bigger rims, but your side wall shrunk ie. lower profile tires) then yes, it will fit! eureka!
IF they are wider or taller side wall then stock, than you could have rubbing isues on the strut body, or the fender, you'll need to adjust your camber, get spacers, or if they're taller tires then you'll need to roll the fender. you'll have to look at the space you have with stock tires, then figure out how much wider your new ones are. If its to much, then your screwed.
1992 Blaze MX-3 GS *R.I.P.*
1993 Blue 93 SE-ZE
http://www.cardomain.com/ride/2770987/2
