CRASH........
CRASH........
well i wrecked my mx-3...
I was rally racing and I got on 2 wheels then went over the rail and flew into a ditch....It was badass.... i'll post some pics soon
but anyway my mx-3 is totaled it's sad....i got a bp and a pro lx tranny sitten around now if anyone is interested
~also i'm picking up a 1986 toyota Corolla SR-5 RWD its sweet anyone know anything about these cars?
93 mx-3 bp, CAI, msd blaster 2, ngk wires,NGK V-powers(just for limegreen). Pacesetter headers, no cat, cat-back 2.25" piping, autometer lunar A/F gauge, 800w 12" sub w/1600w amp. 3 way pioneer speakers all around
- Limegreen mx-3
ur getting the sohc version good luck with that crappy engine. i get another MX-3 shell at the junk yard and but ur bp setup in that.
IF it ain't a GTS toyota Corolla it ain't worth ur time.
- TREVO123
Pm'd you, I want your header and MSD
- papa roached
sounds like its engine swap time with the sr-5
have fun with the corolla man, that should be fun and it'll be easy enough to make it quicker. A friend of a friend of mine has that same car, and it looks really hot and his is actually really quick. He probably put in a different engine... Should be more fun than the mx since it's rwd
1993 1.6L SOHC. Mazdaspeed mounts, BP09 ECU, BP VAF, Fidanza miata flywheel, exedy miata pressure plate, centerforce mx3 disc, tokico struts, B&G lowering springs, and some sh***y motomaster tires.
QFTLimegreen mx-3 wrote:IF it ain't a GTS toyota Corolla it ain't worth ur time.
What does QFT mean?Nd4SpdSe wrote:QFTLimegreen mx-3 wrote:IF it ain't a GTS toyota Corolla it ain't worth ur time.
well i'm getting a 4ag with it and a gts rear end so i'll have 120hp with a lsd....so it should be pretty sweet......
i'm getting a killer deal though basiclly 1k for the SR-5 with the 4ag(60k) to swap in extra tranny and a gts rear end it's sweet
I still have my mx-3 though.....Its pretty rocked i'm completely parting it out so anything anyone wants just pm me the motor has 100k on it and the tranny has 90k the axles have like 300 miles lol so if anyone is looking for pro lx axles lemme know
