Des anyone have any info on the emmisions plug on the b6de
- MechaManZero
The black plug by the ECU that has a wire for the cluster buzzer and the fuel pump and all weird stuff like ac. Does anyone have the pinouts. The online manual is missing the common connectors page in the wiring booklet.
Çlark
95 Mazda MX3 4 Banger
Currently: H&R Lowering springs, BPT from a GTR, 18.5x6x3.5 same side inlet and outlet intercooler, Centerforce Dual Friction clutch
For BPT Frorums - http://www.aokforums.com/mazdaengines/
- MechaManZero
thx man I def need to see a picture of the pin setup. Need to start my BPD.
Çlark
- MechaManZero
Oh yeah also does it say what wire does what cause the common connector page of my gtr electrical didn't say what each piece was for. Plus maybe can you see if you can get the white plug that is right next to the black emmissions plug. It has 6 pins in groups of 2 on the top and two on the bottom left and two on the bottom right. All together the white clip has 10 pins. Do you happen to know what that runs through it.
The only thing I really needed from the black plug on the gtr emmissions set up was the cluster buzzer for over boost, fuel pump, and I forgot the rest I have it all pieced on paper at the shop.
Çlark
- MechaManZero
Nevermind man cause I just went to http://www.alldatadiy.com and found out they give you everything for 24.99 a year. So I got the wiring but if you still do it you give them to custommx3 to put them in the online manual for further references. Anyways I will have a complete GTR swap guide after this so watch for it.
Çlark
