Miles per full tank
Fountainz
Miles per full tank
Post by Fountainz »
Okay. A few people have told me that i'm fuel consumption is over the top. So i thought i'd ask you guys.
I do 170miles (if i'm lucky) to a full tank in a GS k8. Is that bad or normal??
neutral
Post by neutral »
Wow, that sounds low. Would expect at least ~250+ per full tank w/K8, even on a worn motor. While waiting for replies to this thread, run a UBB search on "mileage" as this topic has lots of prior discussion. If your O2 sensors are older than 70-100k, might wanna replace those. Worn-out ones can typically hose mpg by making the ECU constantly guess at the correct exhaust O2 level and resulting fuel mixture...
Image -Jim
Tunes67
Post by Tunes67 »
Thats definately low.. way low.. I was hitting almost 260 miles to the tank for my GS before I tore it down. Granted I didnt drive the car very long before I tore it apart and started the 5 spd swap.. but definately long enough to know that 170 miles to the tank is way messed up. I'd be suspecting leaking fuel injectors or timing WAY off. Do you see black smoke out the tail pipe when you rev the engine?
Tunes67
mitmaks
Post by mitmaks »
I get around 230
fowljesse
Post by fowljesse »
Yeah, that's bad. I get about 270 HWY, and about 310 HWY with the addition of 2-3/4 ounces of Acetone per tank. I have a K&N cone filter CAI. My GS has 150,000 miles on it.
Fountainz
Post by Fountainz »
No black smoke. No smoke at all. the engine has done 73,000 miles. To fill my tank it costs $61.77 thats converted from pounds. I'm guessing its the same size tank?
Tempus
Post by Tempus »
I've got a v6-2.5L (KL engine)
I am not a passive driver, and do have a bit of a lead foot. :twisted:
I get around 23-25 mpg typically when commuting.. (a fair bit of stop and go) I get around 27-28 mpg on long highway trips (like from Seattle area to Leavenworth)
In term of 'tank' that means I typically fill up between 240-260 miles, putting in somewhere between 10-11 gal
{sigh} Time to move on
Out with the old: Tropical Emerald MX-3 GSR (KL-DE)
In with the new: Phantom Blue Mazda3s GT
Tropical Emerald 1993
Post by Tropical Emerald 1993 »
f**k I get only 230 miles per tank with RS :evil:
andy
Post by andy »
I get somewhere between 20- 26 mpg. It really depends on how often
I get into the boost. This is on my 1.8T at 12 psi
Andy P. 93 GS 1.8T
neutral
Post by neutral »
Tropical Emerald 1993 wrote:f**k I get only 230 miles per tank with RS :evil:
That's pretty poor mileage for the 1.6SOHC motor especially. My 95 1.6DOHC averages 31-32 mpg in mixed city/highway driving so ~325+ miles from a full tank. If your engine is in tune, might wanna replace 02 sensor if it has 70K miles or more... A worn out 02 sensor hoses yer mileage...
Image -Jim
hgallegos915
Post by hgallegos915 »
im getting around hmmm 220 per tank.. halkf tank 110 around there... i dont mind because i had read the ze's milleage was around 23 mpg so im good. i guess
-hec
twoie
Post by twoie »
wow that sucks! I get around 280 miles on a tank. Most of my miles are highway driving to and from work, around 70 mph.
twoie
