Any 1 for a mx3?
- XxantwawnxX
hehe took me a bit to find the mx3 cause i kept lookin at the skyline haha
- PWRD_BY_HKS
na man ... the mx-3 over the line any day any time.... mikey has owned skylines before ....and someday i will too
jdmx-3 KID OF THE
VICTORIA RACING
ZE PERFORMANCE IN 915 TX
Kl01-ZE,Kl31 ecu, millenia manifold, ngk plugs, ngk wires, probe tranny/ and clutch (stock), VortecH FMU 12:1, Aeromotive AFPR, Tial .38mm Wastegate w/ 4lbs spring, Walboro 255 pump, AiResearch T4, 3" down pipe, GODSPEED manifold, Spearco Boost Gauges, BF Goodrich G-force drag radials.
14.8 1/4 mile all motor untimed on boost.
VICTORIA RACING
i hate those spoliers on the upper hatch, near the roof, it looks too much like a honda with it...
just a side note
just a side note
1992 MX-3 GS:
http://www.cardomain.com/ride/2607936
1995 Honda Del Sol (Current Main until KL-ZE Swap):
http://teamsolcal.com/forum/showthread.php?tid=20662
- mitmaks
R34 is so sexy, im like wheres mx3
- solo_ryder
