Flywheel balance
Flywheel balance
Post by wytbishop »
95' RS. Bone stock. Hoping maybe one of you knows if the flywheel and crank are balanced together. For example if I take the stock flywheel from my engine and bolt it to my identical replacement engine, will it balance?
Thanks,
Wytbishop
papa roached
Post by papa roached »
each part is balanced by itself, changing the flywheel wont hurt a thing
