bad gas millege
- PWRD_BY_HKS
bad gas millege
okay my car had been sitting for about 2 weeks because the radiator mest up. so i fix it and it starts up right away after two weeks of just sitting on empty i filled up the tank w/ 86 octane gas because i just was being cheap but it is killing my gas now...is it the 86 octane ? was it sitting too long? should i add a fuel treatment additive? i have both of my fans on at all times could that be it???? please help im going broke!!!
jdmx-3 KID OF THE
VICTORIA RACING
ZE PERFORMANCE IN 915 TX
Kl01-ZE,Kl31 ecu, millenia manifold, ngk plugs, ngk wires, probe tranny/ and clutch (stock), VortecH FMU 12:1, Aeromotive AFPR, Tial .38mm Wastegate w/ 4lbs spring, Walboro 255 pump, AiResearch T4, 3" down pipe, GODSPEED manifold, Spearco Boost Gauges, BF Goodrich G-force drag radials.
14.8 1/4 mile all motor untimed on boost.
VICTORIA RACING
- PWRD_BY_HKS
like 24-25mpg compred to 30
jdmx-3 KID OF THE
VICTORIA RACING
VICTORIA RACING
yup 86 octane gives me crappy gas milleage, ecu retards timing due to knocking.. your car is overcooling.. did you resolve that issue? overcooling causes horrid gas milleage and alot of carbon build up which sometimes can be irrepairable... fix the thermostat aand dont drive it. Use 91 octane gas. Anything lower will make your car explode! ok not explode but it makes engine knock. Mix that with overcooling .. not that good.
*edit*
when i drive her hard or well at least a little.. i get around 25 mpg.. so u may be ok?
*edit*
-hec
- PWRD_BY_HKS
hmm.... im gonna wait untill i run out of gas and throw in a fuel stabailer as well as upgrade the gas .... but i dont know man i really hope thats it
jdmx-3 KID OF THE
VICTORIA RACING
VICTORIA RACING
- PWRD_BY_HKS
*bump
jdmx-3 KID OF THE
VICTORIA RACING
VICTORIA RACING
- mitmaks
well its rated at 23mpg from factory (which I usually get with mine) so I dont know why you're complaining when you're getting more than 23
hmm actualy i find that when i run 91 0ctane premium is always the best to rn good milage but its hard to find 94 in canada id so hit that up... its just i think i read befor ehat japan klze's actualy take standard liek 91 in japan im not sure what there ratings are .. but im sure if u do a search u can find the right octan level but doesnt 86 octane run a little weak im sure it can do tha tjob just not that well
1992 mx3 gs Klze with Powder coated black Curved neck Manifold. Hot shot performance CAI, ford probe Gt ECU and MAF
http://www.cardomain.com/ride/2197073
