OBX headers
PWRD_BY_HKS
OBX headers
Post by PWRD_BY_HKS »
i just some for 100 usd ....how is the performance on those.....what are your opinions on them...if you got pix post them please
jdmx-3 KID OF THE Image
VICTORIA RACING
ZE PERFORMANCE IN 915 TX
Kl01-ZE,Kl31 ecu, millenia manifold, ngk plugs, ngk wires, probe tranny/ and clutch (stock), VortecH FMU 12:1, Aeromotive AFPR, Tial .38mm Wastegate w/ 4lbs spring, Walboro 255 pump, AiResearch T4, 3" down pipe, GODSPEED manifold, Spearco Boost Gauges, BF Goodrich G-force drag radials.
14.8 1/4 mile all motor untimed on boost.
solo_ryder
Post by solo_ryder »
I had em on my old mx. Same as the ss-autochrome ones, same weight and everything. One year driving in the winter, the secondary was kinda rusty looking. That being said, I never had a issue with them at all, they worked well and didnt crack/leak
ryan_Fuerte
Post by ryan_Fuerte »
yah i got a set of ss autochromes, i believe they are the exact same design. I could feel the diffrent tourque curve after installing them
Mx-3 GSr : Rebuilt klde with 5spd swap, xtd stage 3 clutch, Magnaflow dual exhaust,Accord custom intake, kyb gr2 struts with eibach springs, civic dual halo projectors, black altezzas, white 15'' oz rims, rolling on dunlop street slicks.
http://www.cardomain.com/ride/2400330
If their 1st gens, ya, installation cost me as much as i paid for the headers to modify them to fit...fun indeed
papa roached
Post by papa roached »
got the second gen style here, install was great, i did it with exhaust at the same time so i really cant say if they helped or not
ryan_Fuerte
yah the only real problem that your gonna run into, is the egr pipe doesnt fit. Just pick your self up a propane torch or even oxy/acetelene if you got it, and just keep heating the pipe up red hot and bend it till it fits.
hgallegos915
Post by hgallegos915 »
He has a ze. Can block egr or no egr. Should have NO fitment issues at all.
-hec
323v6
Post by 323v6 »
with those sschrome headers 2 gen do they still sound nice u know v6 sound like stock or do they sound like crap?
mx3autozam
Post by mx3autozam »
they are equal y pipe so it will keep that deep smooth tone. just pua nice muffler on the end ad it will sound nice,..especially in high revs
93 Mazda MX3 KLZE Turbo
666raCing
Post by 666raCing »
the ss autochrome can fit on the mx-3, even though it's made for probe and mx-6, right?
92 Mazda MX-3 GS
nope-mx3
Post by nope-mx3 »
yeah, but the cat has to be moved a bit further back, wich suck, as it now sits a lot lower because it has to clear the shifter linkage.
-n
Those are mine, pre installation. Horrible fitament. I hope that's not what your getting/got
Juans_93_MX3
Post by Juans_93_MX3 »
Hey I got a question
Do un-equal headers make the car sound kind of like a WRX? Some dude that I know that has a WRX says that his headers are all unequal that why his car sounds bad a--. I told him its because his engine is a flat 4 not a Inline 4 and that the firing order is the reason why it sounds so good
Infact, would having one stock header and the other header as a SS AutoChrome make the car sound any better then just having two SS AutoChromes?
2008 Mazda 3
1993 MX3 GS
666raCing
Post by 666raCing »
Nd4, what do you suggest for headers for the 1.8 v6?
92 Mazda MX-3 GS
Anything but those...
