Installing headers!!!! need some help
- PWRD_BY_HKS
for the rear headers is it possible to do them with out removing the manifold
jdmx-3 KID OF THE
VICTORIA RACING
ZE PERFORMANCE IN 915 TX
Kl01-ZE,Kl31 ecu, millenia manifold, ngk plugs, ngk wires, probe tranny/ and clutch (stock), VortecH FMU 12:1, Aeromotive AFPR, Tial .38mm Wastegate w/ 4lbs spring, Walboro 255 pump, AiResearch T4, 3" down pipe, GODSPEED manifold, Spearco Boost Gauges, BF Goodrich G-force drag radials.
14.8 1/4 mile all motor untimed on boost.
VICTORIA RACING
- mx3autozam
- PWRD_BY_HKS
is that how you did it?
jdmx-3 KID OF THE
VICTORIA RACING
VICTORIA RACING
- mx3autozam
- papa roached
did mine from below, believer it or not the back bank was easier than the front
- mx3autozam
