For anyone who is interested in ARP Head Studs_Never Mind :(
Custom_V6_Limited_SE
Post by Custom_V6_Limited_SE »
Go to http://www.summitracing.com and search for the following part numbers.
part #'s for the ARP head studs are
Item No.......................................... Description
AU4.800-1LUB................................M12X4.80 U/C STUD1.5&1.25 BR
AUN12-2.......................................M12X1.25 12PT NUT STD COLLAR
AUW875........................................M12I D .875OD CHAMF WASHER
I found this info on probe talk http://forums.probetalk.com/showthread.php?t=1701173738
Enjoy :)
Edit: those are for the Probe GT but it's the 2.2L turbo, not the KL-DE :(
Last edited by Custom_V6_Limited_SE on December 7th, 2006, 6:25 pm, edited 2 times in total.
'93 MX-3 GS SE:My Mods
Spinkx79
Post by Spinkx79 »
Ah, so ARP does have a part # for these now. Good you will be happy when you see them. They look really nice.
Did you find #'s for the block studs too?
Not yet, but, I'll look for them...
Zoso124
Post by Zoso124 »
The link comes from the PT 1st Gen's Forum. Are you sure they are the correct PN's for the KL Headbolts? I'm guessing they aren't.
Mike Evans
Gone:
jaydog5678
Post by jaydog5678 »
They won't fit a BP block either....BP's are the same thread pitch as the turbo Eclipse's were. 11MM iirc.
Spinkx79
Post by Spinkx79 »
Msg Babyblue, he was looking to having ARP make more for the KL.
See if he got anywhere with them. He had asked me for measurements of mine but i had no measuring devices that could get the info needed (ie thread pitches and stuff).
The guy who arranged the BB on PT should be able to help...try him.
g/l
Dangit, you're right. I'm pretty sure those are for the 2.2L turbo probe. So close!!! and yet so far away!!!
Return to “Forced Induction”
