Indicator lens broken
Posted: December 2nd, 2006, 2:41 pm
Guys, my fiancee's stupid sister has reversed into my beloved MX-3!
'93 E-Spec V6 in Black. The bumber is damaged, but I think it will polish-out; the main damage is to the driver's-side front indicator unit. This unit is held in by one screw, has a clear lens on the front, and two bulb-holders at the rear: one for the sidelight and one (complete with orange insert) for the inidicator.
I have already called most breakers yards in Ireland, with no success, looking for a replacement. Maybe I could try the UK, but I was wondering if this unit is used on any other (more common) Mazdas, 323 etc. ?
The E-Spec MX-3 is very rare in Ireland - most are imported J-Specs.
The unit can be seen (with sidelight illuminated) directly below the headlight in this photo:
Just below this again is the front towing eye. Thank God it is there; I think more damaged would have been done otherwise!!!
Any suggestions on sourcing a replacement would be much appreciated.
