Question about power steering leak.
Posted: November 23rd, 2006, 4:34 pm
by fabmxer
My power steering pump leaks pretty bad, in 5-10 minutes it leaks all the power steering that I put in. I looked under the car and I don't know where its leaking from, but it could be coming from the gasket, there might be a hairline crack in the pump, or from something else I dont know the name of.
The leak used to be that I had to refill it every 2 days or so, but now it got alot worse, and one time I was driving and all the power steering leaked out, and I couldn't pull over and get some more to refill it, and I was like 10 minutes away from home, so the power steering stopped working and I drove it on empty. Ever since I refilled it its been screeching every time I turn the wheel, but it gets quiter at higher speeds. Maybe I wore the pump out?
I know its hard to say without looking at it, but you think just a new pump should fix all of this, or what else could it be?
appreciate the help....
Posted: November 23rd, 2006, 6:08 pm
by mitmaks
did you check reservoir, maybe its cracked
Posted: November 24th, 2006, 2:43 am
by fabmxer
Yeah, I pulled it out, washed it and tested it, it looks good,
Posted: November 24th, 2006, 2:47 am
by hgallegos915
There is a stupid defective gasket.. in the pump itself... gotta take it out and make your own.. well at least thats what happen to mine.
Posted: November 24th, 2006, 3:13 am
by fabmxer
Well I know it takes like $2 to make a gasket which is alot cheaper then the pump, but if I'm alredy taking out the pump ( which probably takes a couple hours??? ) I dont mind replacing it entirely. Is that a good idea?
Thanks
Posted: November 24th, 2006, 1:06 pm
by mitmaks
ya might as well get new one and get some money from that core
Posted: November 24th, 2006, 1:18 pm
by neutral
Or check with Trevor. He has a used pump for sale here for reasonable price.
http://www.mx-3.com/phpbb2/viewtopic.ph ... highlight=
Posted: November 24th, 2006, 2:01 pm
by hgallegos915
Well it only takes around 20 mins to take the pump out. Yeah newer is better. Make sure pump comes with that copper pi[pe.. if it doesnt. You gotta make the gasket anyway.
Posted: November 25th, 2006, 1:10 am
by fabmxer
hmm... 20 minutes? I hope so, my brother told me it could take a couple hours, but to check the book to see what I gotta remove. If it takes that short, thats awesome.
So what do you mean by the copper pipe, ? If I call a local auto parts store do I ask if it comes with the copper pipe, or what? And shouldn't the new pump come with a gasket?
Thanks for the responses.
Posted: November 25th, 2006, 3:18 pm
by hgallegos915
The copper pipe is the pipe attached to the power steering pump, then its attached to the hose going to the resevoir. If its gonna come without the pipe.. you need to make a gasket for it. Defeating the purpose of getting a new one.. To remove.. simple removebelts, remove power steering pulley. Remove bolts and comes out. The first time I did it took me hmm around 45 mins the most. An inexperienced mechanic may take a bit longer but.. again its direct bolt on so its not like if you are modifying anything.
Posted: November 25th, 2006, 8:39 pm
by fabmxer
Oh ok, now I know what your talking about, Thank you.
Posted: November 26th, 2006, 1:29 pm
by mazdaspeedmx_3
it comes down to how long it takes you to undo the 5 bolts the two fittings for the hoses and loosen off the belt...its pretty basic
check the little copper compression washers where the fittings attach to the pump....if the get banged around to much they could start leaking and it'll squirt out all your fluid in a hurry
Posted: December 1st, 2006, 9:06 pm
by fabmxer
I went to the autoparts store,and there are a couple different kinds of power steering pumps. One I think is like circle rounded hub, or square hub with raised middle, or something like that. Which one do I buy for the 1.8 GS 1993 model, ( I did the KLZE swap if it makes a difference )
Thanks.
Posted: December 5th, 2006, 12:17 am
by fabmxer
Sooo... Kragen Autoparts had the pump for like $40-$60 , and Pep Boys had it for like $160 lol
I ended up not buying anything and attempt to replace the power steering gasket. Appears there was no gasket, only the O - Ring, So I made a gasket and let it dry for 18 hours and now it runs PERFECT.
What I had to do was take off the tire, take off the accessory belt, take the power steering pulley off ( even though the book says I dont need to? ) and I unbolted the power steering copper piping from the pump, but I left the pump and everything on, and there was enough room to make a gasket without actually taking the whole pump out, which was good.
Hope that helps to anyone who had the same problem ...
