my new connecting rods
- papa roached
think they can take some boost?
thats pure HOTNESS
-hec
- papa roached
no brand, they were made by a race shop that specializes in rods
- jschrauwen
- XxantwawnxX
thats what i need....im so afraid for my rods : (
- jschrauwen
- mx3autozam
- mx3autozam
- papa roached
it was a limited run by a rod maker to fill downtime, there was only like 16 sets made and they are all gone, got them from a GB over on PTjschrauwen wrote:I believe Spinkx79 has been searching for some good connecting rods (or was that pistons). Are these custom ones available to others?
- Josh
thoes look exactly like the rods in my BP. look like Carillo H beams. they should do nicely, I know the Carillo H beams are about as strong as they come. should be nice to boost a V6 as much as the BP.
