OEM Piston for KLZE
Ice Racing
OEM Piston for KLZE
Post by Ice Racing »
I am looking for mazda original part number for klze piston. I have to install new ones (oversize). I also want to shave the heads, is 0.0040 too much?
GS KLZE FOR ICE RACING
mazdaspeedmx_3
Post by mazdaspeedmx_3 »
from what i read on probe talk you can shave up to .080 off before its an interferance engine....i think corksport sells the new ZE pistons
2006 best ET 14.43 @ 96.9mph
93 MX-3 GS-95 Curveneck klze, kl-01 cammed,homemade CAI,HEI module, chipped kl-07 ECU,UDP,KYB GR-2 struts,DropZone lowering springs, Toyo Proxes 4's 205-50-r15
parts to be installed:Turbo hot pipes,T04E/t3 50/63 57 trim, ssqv BOV, hks style 38mm wastegate
the rest of my turbo set up and IPP hp rebuild kit is in the NEAR future
SOON TO BE MX-3ZE-T
kiwi_MX3
Location: Backpacking in Canada in vancouver 13march onwards
Post by kiwi_MX3 »
mazda did'nt produce OEM oversized pistins so you will have to look
aftermarket for something.
as for shaving 0.004" off, that would not even compensate for a valve
regrind
Ice Racing
OEM Piston for KLZE
Sorry i meant 40 thousand of an inch. I want it to be safe for racing (reliable)
kiwi_MX3 wrote:mazda did'nt produce OEM oversized pistins so you will have to look aftermarket for something.
One guy recently got a ZE rebuild kit from CorkSport and they came with .050 overbore pistons, Mazda OEM
http://forums.probetalk.com/showthread.php?t=1701214996
(If it wasn't xmas time, i'd pick that up)
JM1EC-V6
Post by JM1EC-V6 »
totally false. Mazda produces oversized pistons.
'94 Mx-3 GS-R SE, KL-ZE Interprep. (From '96 PGT KL)
1110Kg
-Interprep KL31 Spec.
ported heads, Polished combustion chamber,3 angle vlv job,10.3:1 C.R.,0.020'' O.S.,KL31 cam,-0.007'' heads,Long neck IM,KL31 TB, Hotshot headers,2.25'' exhaust,Magnaflow cat
jschrauwen
Post by jschrauwen »
JM1EC-V6
Gender:
I enjoyed some wild times in sister city - Bagotville
kiwi_MX3
Post by kiwi_MX3 »
jschrauwen wrote:JM1EC-V6
Gender:
John you party aniamal.
mx3autozam
Post by mx3autozam »
Mike is taht the link i sent you?
Thats a nice kit he ahs but thsoe are de pistons look at the dome. He claims there ze but I know there not.
93 Mazda MX3 KLZE Turbo
Ice Racing
How sure are you that they are not KLZE ? Can anybody check and confirm part number direct application with Mazda ?
mx3autozam wrote:Mike is taht the link i sent you?
Would be
mx3autozam
Ice Racing wrote:
mx3autozam wrote:
Nd4SpdSe wrote: One guy recently got a ZE rebuild kit from CorkSport and they came with .050 overbore pistons, Mazda OEM
Have fun talking to Mazda about a klze. they will have no idea what it even is.
We all know that ze pistons are flat top and de are concave.
kiwi_MX3
Post by kiwi_MX3 »
Kiwi fluff's his feathers,
Those are not ZE pistons in the photo's at all.
Ice Racing
PISTON
OK then, where can i buy regular flat top piston? not the expensive stuff but regular...
leo323
Post by leo323 »
regrind
well im totally oposite iv chaved my heads to .50 made 30 more pounds and made adjustable sprokets and i compensated the timimg it worked realy nice the timing is just as stock very nice work id thinck it will work just fine ...
11.20 @120 1.58 60 ft ALL Motor KL
