Headlights relay unit number??
Hi chaps, does anyone know the number of the headlight relay unit? my headlights keep going off whilst driving which isn't good, a guy on ebay has some relay units for sale but doesn't know which is for the headlights. Many thanks, Sloggy
- jschrauwen
If it's for the DRL's (Daytime Running Lights), it's best to verify your own just in case there were different ones used between the NA and EU. Simply pull the center consol kick panel away on the passenger's side and look in front of the ECU location. Your DRL relay is located there and the numbers should be easily captured. g/l
