Compression tests ok. Valve cover gasket change only?
Posted: November 1st, 2006, 12:44 am
Hi everyone,
This is my first post and I'm glad that I found a community that will (at least theoretically) be a good place to learn and help others work on their car.
The car is a '92 4cyl manual with 170k miles. I rescued her from a crackhead (quite literally) out of South Sacramento. It needs a lot of work and I knew that when I bought it but I enjoy working on cars and I like having projects.
I changed the plugs, wires and the oil today. I also did a compression test on all 4 cylinders and they were between 155-170 which is not so bad for 170k mi... right? If I'm reading the (right part of the) manual, then I should be seeing something between a mininum of 142 and an average of 185. If 185 is the norm, then I'll consider myself very lucky.
The engine has a really bad oil leak. It looks like it's coming mostly from both sides of the block, but since I know the car hasn't been taken care of and cleaned, I can't tell how old the dirty oil is nor tell exactly where it's coming from. I was planning on changing the valve cover gasket soon, but I don't know if there are any other gaskets/boots/etc for the cams that I need to buy ahead of time. I may change the head gasket also, but if the compression readings are good enough (are they?) then I may hold off on that until later.
I am also planning on changing the belts while I am tearing the engine apart which will hopefully be all I need to do for the mechanical stuff for now.
A non-engine question if you all don't mind answering. Are there any cabin aka micro filters? I couldn't find anything in the manual or searching through the forum about it. The PO was a bad smoker so that even the air smells when coming through the vents.
Thanks for the help guys and nice forum/site.
Geroi
Geroi
