Page 1 of 2
draining out gas from gas tank
Posted: October 25th, 2006, 2:38 pm
by Mr Garage Sale
There a full tank of gas in this parts car that I have. I was wonder is there a way I can drain out the gas through a line in the engine bay? (EX through the fuel filter or something) Any information and pictures would be appreciated thanks everyone.
Posted: October 25th, 2006, 11:09 pm
by Bumpysbro
is there any power? if you can get the pump to turn on, crank her over and take off the line and shoot it into a bucket haha.
Posted: October 25th, 2006, 11:26 pm
by ariesdude
There is drain plug bottom of the gas tank....
good idea
Posted: October 25th, 2006, 11:53 pm
by Mr Garage Sale
Yup the car starts up and runs fine. I already thought about draining it from the gas tank but it will be messy. So where would I be able to find this LINE your talking about. Is it under the hood?
Posted: October 26th, 2006, 3:02 am
by Bumpysbro
the drain plug will be messy but alotttt quicker haha then trying it this way, well there are 2 lines an input from the tank to the engine and the output the left over gas that goes back to the tank. the input line is the one you want, look for the fuel filter and follow that line to the fuel rail, disconnect it so it never gets to the rail and put a 2 liter coke bottle or something and if you turn the key to on and it should try to prime the system. c if it comes out if not crank her over and see if that does it.
Posted: October 26th, 2006, 9:39 am
by Custommx3
If your trying to drain the tak. just jack up your car and put a bucket underneith the tank drain plug and remove it.
Posted: October 26th, 2006, 11:56 am
by torpedan
The last time i needed to drain a gas tank I hooked power stragiht to the fuel pump so it would run without having to have the car on. I also ran a hose from the pump to a gas can(or if you have enough length just to another cars gas tank) and let it run till it was empty.
yipee I did it
Posted: October 26th, 2006, 11:23 pm
by Mr Garage Sale
I've found the fuel line leading out of the fuel filter but the only way that fuel comes out is when you crank it. So I hook up my battery charger on boost mode then I cranked it till the battery was dying it drained out most of the tank. Now the low fuel warning light is on I say I drain out close to 30L or more. I am very happy now. Thanks for all the info
Re: draining out gas from gas tank
Posted: October 8th, 2009, 5:27 pm
by Ryan
next time someone wants to do this, turn the key to ON and jump F/P and GND in the diagnostic box....instead of cranking it, or jimmy-rigging power to the fuel pump itself. Not necessary at all.
Posted: October 9th, 2009, 9:01 am
by nos92mx3
or if you have a factory gas tank, you can utilize the drain.
Posted: October 9th, 2009, 12:42 pm
by Ryan
But I don't have a 40L tank that fits under a car on jackstands.
Posted: October 12th, 2009, 11:32 am
by Ninjaskill
Ryan wrote:But I don't have a 40L tank that fits under a car on jackstands.
use one of these:
http://www.autozone.com/autozone/catalo ... Name=Blitz
just do it in a couple of dumps.
Posted: October 12th, 2009, 11:54 am
by marcdh
Jiggle syphon would be an easy job I would have thought.
Posted: October 12th, 2009, 11:55 am
by Ryan
Yes, there are lots of options.
Posted: October 12th, 2009, 12:09 pm
by marcdh
Good to know.
