RPMs Drop to Zero While Driving
92 MX3 driving along fine then RPM's drop to ZERO as I pull over sometimes they jump back up and car resumes as if nothing happened- othertimes car stops and is hard to start. Mechanic tested for vacuum leaks and can get no resistance on JE-50 VAF. Is it the VAF or should I be looking at HEI module as culprit?
- tehbrookzorz
if you are sayin the rpms cut out and engine dies. than yes you need a distrubtor or the hei mod.
if the engine dies and the tach drops slowly as engine stops spinning than it is fuel / engine managment related.
JUDGE ME ALL YOU WANT
93 gs, klde swap, kl trans, strait 2.5'' ehaust, euro front bumper, cold air intake, hei ign ,50 shot &
9.60s n the 8th mile so far 8.50s sprayn now
150 shot
150 shot
