swapping IM
ElectronBlue
swapping IM
Post by ElectronBlue »
k im a noob at this... but im wondeirn gif i wanted to change my intake manifold to an MS8 is it possible to do it without removing it out of the engine bay
1992 mx3 gs Klze with Powder coated black Curved neck Manifold. Hot shot performance CAI, ford probe Gt ECU and MAF
http://www.cardomain.com/ride/2197073
mx3autozam
Post by mx3autozam »
What are you trying to say?..............You wanan remove an intake manifold well of course your going to ahve to remove it from the engine bay!
93 Mazda MX3 KLZE Turbo
Custommx3
Site Administrator
Post by Custommx3 »
YOU can swap ot with out having to remove the engine if thats what your asking. Just be sure you have plenty of vaccume hose, and have the vaccume hose diagarm with you. Id have the ms8 manifold already prepered with vaccume lines attahced before doing so. Also, make sur eyou clean the surface where it mounts to the head preior to doing so, and if there is going to be any time where the car will sit with the manifold off, cover up the ports on the heads to keep debris from entering the cylinder.
ElectronBlue
thanks guys
