idle all over the place
sleeper_hoops
Post by sleeper_hoops »
when i first start my car it idles around 25 hundred rpms, but after a while it will idle really low and rough. but if i pop it in to netural while im moving it will idle at 15 hundred rpms.
Any thoughts?
Custommx3
Site Administrator
Post by Custommx3 »
TPS adjustment, should be in the FAQ, also check for vaccume leaks, esp in the intake tube.
tehbrookzorz
Post by tehbrookzorz »
TPS or IAC Valve
Cody
Teqnyck
Post by Teqnyck »
Try cleaning out your TB with a degreaser, too. For some reason, that worked for me when my car was doing the same thing.
KLZE/KL31 ecu/Pacesetter headers/track pipe cat delete/2.5 inch custom exhaust out to fart pipe/warm air intake for now :(/Fidanza 9lbs flywheel/Stage 2 kevlar road racing clutch which still slips/stock wheels/BFG KDW-2 tires. Looks bone stock ;)
There are those who claim to be street racers, and then there are those who claim the streets for themselves. I am not a street racer. I am a StreetSweeper.
http://www.streetsweepersracing.com
chertel
Post by chertel »
I just had the ze swap'ed in and my mechanic tried everything and it still idles up and down..... when the engine is at operating temp. He said there is a part that fixes it but its like 5-$600. Does anyone know what that part is called? I forgot to ask?
hgallegos915
Post by hgallegos915 »
I fixed my idle up and down yesterday. It seems a combinaton of adjusting the top idle screw to the most closed setting u can and adjusting the throttle FLY's screws. Its driving fine after that. Also reset tps but that didnt seem to do anything.
-hec
tehbrookzorz
Told ya.
Cody
