throttle body coolant lines
- GreenMachine
ok Ive almost got the ze swap finished, and now I have to find where the coolant lines come from/go to the throttle body. I have the one hooked up correctly in the front, but where does the one on the back of the throttle body hook up to? Also on the radiator, drivers side there is a nipple coming out of the top about the same size as the over flow line. what is supposed to hook up to this nipple? I searched but turned no usable results. and btw, thanks to the site for helping with the info to get the ze in there!
'92 GS-no lip. Klze. no cat. phenolic spacers. no power steering. no a/c. hei mod. poly filled mounts. probinator chip. loud exhaust. b&m shifter. tokico struts. suspension tech springs. axxis 17 in rims.
'86 mr2-stock and still hauls a-- in curves.
'05 Gsxr-50 tooth stunt bike
- mx3autozam
- GreenMachine
ok well I have the egr on there for cali smog. so lets see if i have this right. nipple on rear head ->throttle body front->throttle body rear->nipple on egr. is that correct? and i thought the thermostat housing was on the other side of the motor, no?
no particular order.... Just connect to all of them
1 mx6 88 LX auto 2.2l 4cyl
2 mx3 93 gsze bought w/ mods
4 mx3 GS SOLD-
2 pgt primered 5 spd KL SOLD
4 mx3 GS SOLD-
- GreenMachine
oh ok. just seemed funny to me that it ends at the egr. does the egr route the water back into the block at all?
