I believe I need to replace the crank pos sensor on my 93 1.6, if I read the check engine code correctly. It seems to be causing a misfire feeling and after the car warms up it almost wants to stall when coming to a stop. I was wondering if someone could point me towards some guidance on replacing this?
Also, can the seat belt warning chime be removed or the sensor disabled? Mine just keeps going on all the time.
thanks
Nick
Replacing crank position sensor
