Performance Structs/Springs no Drop
Posted: August 7th, 2006, 12:11 pm
by nightnic
Can everyone suggest any option of getting aftermarket (performance) struts and springs (may be adjustable coilovers also) with option to KEEP ride height, please? Harsh roads.
For the time being looking through on everybody's opinions I'm going for Tokico ZX2 S/R struts, Eibach springs (250#/200# spring rate (what does that mean anyway?)) and may be a groundcontrol coilover kit.
I also know that Tokico will rub against 205 sized tire, and I have 205 on 6.5" rims. Will getting 7" rims help against rubbing? Or do I have to go for spacers?
Re: Performance Structs/Springs no Drop
Posted: August 7th, 2006, 12:50 pm
by lakersfan1
nightnic wrote:Can everyone suggest any option of getting aftermarket (performance) struts and springs (may be adjustable coilovers also) with option to KEEP ride height, please? Harsh roads.
There is NO spring that will not drop your car.
The struts you use has NO bearing on if they'll rub on your wheels or not.
Posted: August 7th, 2006, 1:05 pm
by nightnic
Why not? Stock springs will not lower my car. Actually, even GroundControl description mentions 0-2".something drop. This as I understand is mostly affected by struts themselves (since Tokico are shorter) and also by springs. There are shorter springs on market, why not be same as stock? This explains first question.
The stock struts I use now do not rub my 205 tires, though, I sought a number of posts mentioned Tokico ones do. No wonder, though, why strut assembly cant be a millimeter or two wider? This explains second question.
Posted: August 7th, 2006, 3:23 pm
by lakersfan1
Less crack.
Posted: August 7th, 2006, 4:21 pm
by nightnic
huh?
Posted: August 7th, 2006, 4:36 pm
by Hoodzy
the ground controls should give ua min height u can drop them... if u go with zx2 struts that gives u a drop by itself... so thats gonna be ur only option if u dont want a drop
Posted: August 7th, 2006, 8:48 pm
by solo_ryder
lakersfan1 wrote:Less crack.
nightnic wrote:Why not? Stock springs will not lower my car. Actually, even GroundControl description mentions 0-2".something drop. This as I understand is mostly affected by struts themselves (since Tokico are shorter) and also by springs. There are shorter springs on market, why not be same as stock? This explains first question.
There is no real aftermarket spring that will not drop the car. You can consider Suspension Techniques springs (1.3" drop) or Eibach (1.5" - 1.2"), if you have such bad roads you may not want to stiffen your ride? With just a suspension techniques spring and whatever strut, you will still be fine to drive around, specially if you have no gs lip.
Posted: August 8th, 2006, 3:31 am
by nightnic
Ok, I got the idea, thanks
What about tires rubbing?
Posted: August 8th, 2006, 10:44 pm
by solo_ryder
nightnic wrote:Ok, I got the idea, thanks
Shouldnt be a issue man, make sure you get some camber bolts and get a alignment done.
