An easy one for ya... what size wiper blades?
Posted: July 31st, 2006, 11:25 am
by Wilhelm_Fink
Driver, passenger and rear blade sizes please. I think the last owner put the wrong ones on all round, and I don't have the owners handbook to check/replace them.
thanks! (search didn't help)
Posted: July 31st, 2006, 1:18 pm
by 1992blazeredgs
Just take them off and bring it inside with you at the auto parts store. Most wiper blades can be taken out of the package without ripping it. Pretty easy fix.
Nate
Posted: July 31st, 2006, 11:42 pm
by NorCalMX3
mine are 18 inches
Posted: August 1st, 2006, 1:28 am
by ariesdude
I think rear and driver are 21 and the pass. side is 18
Posted: August 1st, 2006, 6:34 am
by Wilhelm_Fink
thanks for the help, but can anyone check their MX-3 owners manual to see if it tells us for sure?
My wipers squeek like crazy, and I know their definately the wrong size.
Posted: August 1st, 2006, 2:40 pm
by ariesdude
Go to the parts store and tell them the year/make/model and they will be able to tell you what you need.
You can also check online at
http://rockauto.com
http://partsamerica.com
http://autozone.com
etc etc
Posted: August 3rd, 2006, 12:34 am
by Typhoonk
I use 21inch on the rear (stock). 18 on the drivers side (stock is 21). 16 on the passenger side (stock is 18)
I use the smaller size on the front because the wipers always hang off the passenger side and, wipe over and off the window on the drivers side.
I like it better like this
also those one peice no hing wipers are awsome at high speeds
Posted: August 5th, 2006, 11:36 pm
by 2RotorsNaDream
Front drivers side is 21 inches. Front passenger side is 18 inches and rear is 21 inches. Every parts store has a giant book that will tell you everything you need to know for replacement parts from blades to fuses to light bulbs.
Posted: August 6th, 2006, 2:08 am
by 2fazed
I put 24's on mine. I like more of the window to be washed. You can put whatever size you want, as long as the driver and passenger wipers don't touch.
Posted: August 6th, 2006, 3:58 pm
by 95Precidia
I have 20's on both of my driver and passenger
