Mtx and Atx ecu?
- Mx3Baker
Mtx and Atx ecu?
Im doin a atx to mtx do i need to change ecus?
93 Mx-3 GS
5 SPD Conversion
Worklog at
viewtopic.php?f=46&t=54796" onclick="window.open(this.href);return false;
5 SPD Conversion
Worklog at
Keep it in the same thread
I dont think so though
Only time you have to change the ECU is when doing a engine swap and even then, its optional
2008 Mazda 3
1993 MX3 GS
1993 MX3 GS
u dont need it, it will just detect some error code i believe? which you can bypass. I did an atx to mtx swap in a previous automobile. I had to ground the neutral start switch (clutch switch)
-hec
it will not give any code but you do need to loop a wire
01 Lexus Is300 (LS2 Project)
93 Mx3 SE 2.5 KLZE (sold it)
just follow the directions on the auto to manual swap. Its really not that hard.
1 mx6 88 LX auto 2.2l 4cyl
2 mx3 93 gsze bought w/ mods
4 mx3 GS SOLD-
2 pgt primered 5 spd KL SOLD
4 mx3 GS SOLD-
not that im nosy but since you only have 8 posts and been asking the same question. perhaps you should try searching. actually searching is not even necessary, try looking in the faq.
you will find this link there
http://www.mx-3.com/phpbb2/viewtopic.php?t=34794
simple search will yield you tons of mtx to atx conversion results
http://www.mx-3.com/phpbb2/viewtopic.ph ... conversion
when i did my first atx to mtx conversion on my 3rd mx3 i personally found over 20 threads. the only things i couldnt find were the pictures of which wires to jump on the atx harness but i found that for you too...
search function is great. i have been able to complete just about every project i started on my mx3's because of it and for that i am a firm believer in learning to use it.
- Mx3Baker
Yea im sorry for posting so many times but thanks to everyone who helped im just so exicted about it and cant wait
93 Mx-3 GS
5 SPD Conversion
Worklog at
5 SPD Conversion
Worklog at
