I need help
tateandlyle
I need help
Post by tateandlyle »
I have a 94 Mazda MX-3 4cyl and it wont start It has spark and getting gas but it wont start. It was running fine but the spark plug wires melted and when i replaced them it wouldnt want to start. I also replaced the distributor cap and rotary button. Does ne one know what the problem could be??
Custommx3
Site Administrator
Post by Custommx3 »
Check your codes 1st. If you had a wire melt you may have something else burned out. Jump GND to TEN in the diag box, put the key in the ON position, and count the Check engine light blinks. Refer to the online manual for what the codes mean.
Rayted_m
Post by Rayted_m »
if not check your ignition wires
**~Rayted-M~**
Team **~N.M.E~**
**~CROWN LEGION~** Caloboration
MX-3 Civic head light conversion
http://www.cardomain.com/ride/688645
