Ontario Megasquirt Users
A Forum For Ontario MX-3 Club Related Topics.
jschrauwen
Post by jschrauwen »
If there are any successfull MS users in Ontario, I sure could use your assistance / guidance. I'm not having very much luck with my V3 Plug n Play unit. Since I have a spare ECU, I can drive to your place where I can hook up the MS and perhaps show me what or if I'm doing something wrong. Any help would be appreciated. Cheers,
John
Maybe a drive up to Ottawa/Hull to see Steve might be in order???
babyblueMX3
Post by babyblueMX3 »
I didn't play with the V3 really. You got the plug and play and I would've guessed it is the simplest. don't you just replace the stock ecu with that one ? I had the first version that got out where you tap each wire.
Can you give us more detail on that john ? did you try to hook it up ? what happened ? Maybe we can find the problem here.
RIP 400whp ZE-T MX-3
Return to “Ontario MX-3 Club”
