Coil-Overs Suggestions
Ok so with my new Pakfeifer front bumper on i'm sitting WAY! to low, So i'm now looking into getting a set of coil overs to lift my self up a bit, So what does everyone use/how do they work for you? I would like to hear about coil overs or true coilovers (springs and struts) and people opinions on them.
i just bought tokico struts and intrax springs...not sure how low I will sit but will post pics on install...90% of mx-3.com will tell you that GC (ground control) coil-overs are by far the best set you can get...the only thing better would be mazdaspeed struts lol if you can find some....
http://www.cardomain.com/ride/2385931/4
Car Name - Elsie (LC)
Car Type - 92 Black RS Stock 190k
Car Name - (yet to be decided)
Car Type - 93 (soon Black) GS KLZE 130k
if you can find mazdaspeed struts i would also recommend getting your ground control coilovers in the same or close to the spring rates that the mazdaspeed springs were offered in.
if it were me, i would go with koni 86 series dampers since they are adjustable and can handle higher spring rates that ground control offers. they are probably a bit cheaper, rebuildable and revalvable.
