K so i'm trying to install my msd digital window switches, and i've run into a snag.
out of each switch runs 2 wires yellow (constant ground) and gray (removes ground)
now on the vris:
vris 1 there is a White/red wire and a Brown/white wire
vris 2 there is a white/red wire and a Green/orange wire
What goes to what hahahaha? And before someone asks yes i have a multimeter but my roomate is a technician and he had to barrow it and is out of the state till saturday.
Any clues?
VRIS GODS!!!!! Schematic doesnt tell me squat!
01 Lexus Is300 (LS2 Project)
93 Mx3 SE 2.5 KLZE (sold it)
- johnnyb
judging by the wiring diagram that you posted along with the diagram on page z40 as it says the W/R is connected to the relay from the positive side of the battery
http://www.mx-3.com/95manual/Z/Z-040.gif
if you follow the diagram on z40 you will see where it references in the top right hand corner to the solenoid valves.
hopefully this helps you out. My guess would be W/R is the gray wires and the others are yellow.
