Page 1 of 2
t3/t4 and civic radiator installed
Posted: June 17th, 2006, 3:29 pm
by blooprint
take a look. just copy and paste the link.
http://www.clubprotege.com/forum/showthread.php?t=25155
Posted: June 17th, 2006, 5:49 pm
by hgallegos915
ive never seen that , awesome :) where did u get fan?
Posted: June 17th, 2006, 6:38 pm
by cjthor
Can anyone post the pics here? I am at work and cant see that site!!! Thanks.
Posted: June 17th, 2006, 8:12 pm
by XxantwawnxX
Looks nice too! What psi u running and is that a t3/t4 with the 57trim compressor and .63 hot side?
Posted: June 17th, 2006, 8:21 pm
by blooprint
yup. its a 57 trim with a .63 hot side. i'm running only 8lbs until i can fix a leaky fuel injector. has lots of top end though!
Posted: June 17th, 2006, 8:27 pm
by XxantwawnxX
I was thinking about getting that same turbo for the ZE cause my .48 t3 is to small. : ) its either gonna be that turbo or the 60-1.
Posted: June 18th, 2006, 12:56 am
by blooprint
t3/t4 would be perfect for the ze
Posted: June 18th, 2006, 1:12 am
by Cy
WAIT SO DOING THE CIVIC RAD MOD = MIATA BP MANIFOLD FITS NO MODS??????!!!!!
caps lock DEFINETLY intended
Posted: June 18th, 2006, 9:59 am
by atlantamx3
Uhh i dont think so. He is saying he has a N/A BP Intake Manifold.
That Turbo Manifold looks custom. The Miata ones dont come that far away from the head if I remember correctly, not to mention they place the turbo a bit higher in the engine bay.
Posted: June 18th, 2006, 3:06 pm
by blooprint
ok. it is a miata turbo manifold. assuming that you use a standard t3 turbo, it will fit with only one mod. you have to notch the power steering pump bracket. the only reason i had to use a civic radiator in this setup is because the larger t3/t4 doesn't clear the radiator.
Posted: June 18th, 2006, 7:52 pm
by Cy
blooprint wrote:ok. it is a miata turbo manifold. assuming that you use a standard t3 turbo, it will fit with only one mod. you have to notch the power steering pump bracket. the only reason i had to use a civic radiator in this setup is because the larger t3/t4 doesn't clear the radiator.
your my hero... so what about the 1.6l (which i assume you had first?)
would a b6 miata manifold fit it.. I mean if your not having hood clearance issues then i shouldn't if i drop the front engine mount a 1/2 inch..
Posted: June 18th, 2006, 11:31 pm
by MechaManZero
Awsome
Posted: June 19th, 2006, 1:33 am
by PATDIESEL
Looks good, but I don't see how that crappy little radiator is going to keep things cool with the hot side of the turbo right next to it, and the fact that it is about half the size of the stock one. I would suggest an upgraded radiator and fan and wrap the downpipe. my .02
Looks good though and should give the 4 banger guys some good ideas since the parts used are widely available.
Posted: June 19th, 2006, 1:59 am
by Cy
PATDIESEL wrote:Looks good, but I don't see how that crappy little radiator is going to keep things cool with the hot side of the turbo right next to it, and the fact that it is about half the size of the stock one. I would suggest an upgraded radiator and fan and wrap the downpipe. my .02
B18c civics (the Type-R motor) run with turbo setups on 1/2 a rad...
An upgraded doublethick civic rad and a full heatshield would lower your engine temps and your hood's temperature...
Question: Turbo being mounted up isn't the hood going to get hot.. .Like paint bubblingly hot...????
Posted: June 19th, 2006, 6:39 am
by XxantwawnxX
dont think so, us v6 guys have it mounted like pretty close to the hood...i have not had bubbling yet....or fading.
