question about the klde swap
i have a klde just waiting to get in but i was wondering if i will be able to keep my air conditioning? i was also wondering how does the ze fit underneath the hood? i plan to get a ze intake manifold, plus have spacers from the heads to the intake manifold, just wondering if it will be bumping my hood, or if it will be ok? also plan to get headers, so that's why i'm wondering about the whole ac thing, it gets really humid over here when it's summer!
- solo_ryder
have fun
once you get that bad boy in have fun
- 1992blazeredgs
strait neck ZE mani wont fit. blazered is correct, the tbody hits the master cylinder. The DE mani also is very close there as well. Look at when you swap because I almost ripped off my master cylinder b/c the tb caught on it.
Ac will be fine, mine worked until i took it off.
By the way its SOOOOOO worth it. The car much more fun to drive
- jschrauwen
Hmmmmm, *scratch's head and is trying to figure out why one would go through the arduous process of an engine swap with a DE and then continue with installing a ZE intake manifold*. For the gains, albeit modest, why not make this whole process pay off even bigger and swap in a ZE rather than a DE. Why you ask, hmmmm, perhaps that any DE that is sourced these days, it's going to have nearly as many miles on it as our K8 engines. So we haven't gained a whole heck of a lot here. But, on the other hand, sourcing a ZE from an importer could net someone an engine with approximately 30 - 50 k miles on it. A substantially lower amount than any DE would normally be. Sourcing a DE or a ZE from importer "X" will probably cost only a few hundred dollars difference anyway. Now lets through into the equation that when sourcing that ZE you're already going to get a ZE IM. But the real kicker is the projected longer life to be expected from the ZE and let's not forget that big jump in HP over the DE engine also. If anyone was ever to do a swap with a K8 I'd always recommend a ZE. Well unless someone went and dropped a completely rebuilt DE on your doorstep, then I'd rethink what I just said.
Issues with clearance with ZE IM's. Subject has been covered in depth if a search was done utilizing perhaps spacers, phenolic, clearance, outlaw as a few key words. Only clearance issue to be concerned is if you want to use the MS8 IM. Some refer to it as the straight neck but I believe that it's designation is actually a long neck and the KLDE IM on the PGT would be considered the "short neck". At any rate the straight neck IM has definite clearance issues with the brake master cylinder. There are ways around that but I believe it's a closely guarded secret amongst the rank and file. The Eunos 800 (ZE curved neck) IM will have no clearance issues with that brake cylinder or with the (OEM) hood.
John
John
