car wont start! help!
Car wont start no spark I cheked the spark plugs, Spark plug wires, distributor, and ignition harness and everything fine! what could it be?
what does the fuel filter have anything to be with the spark problem? the last time it was turned on was 5 months ago, finaly I had installed my tranny and when trying to start it wont start and cheked for spark and that was the problem no spark
then I cheked the spark plugs, spark plugs wires, distributor, ignition harness, starter, starter terminals and wires, and everything looks fine what else could it be the only thing I have change since the car wont do no spark was the fuel filter
Have new battery!
Have new battery!
Did you check all of your connectors ? i know theres one mounted on the front of the transmission that senses wheather your clutch is beiing pushed in or not. It controls weather your car starts or not. I forgot to connect this after i did my clutch change and my car wouldnt start. also theres two other connectors under the dash above the clutch pedel that control the same function.
Apexi Safc 2 ,Timex Boost-Temp-Oil Gauges, Stage 1 Performance clutch, 8.5 mm Magnacore plug Wires,2.5 inch exhaust, Cold Air Intake , Short Shifter , High temp rotors & Ceramic pads to slow it all down !
If the neutral safety switch is not configured properly the engine wont even crank.ModMX3 - (Carmaster2005) wrote:finaly I had installed my tranny and when trying to start it wont start and cheked for spark and that was the problem no spark
Are you sure both connectors to the disty are plugged in properly? Did you check for codes? How did you check for spark?
94 Mx-3 Precidia
