Experts I need your help
Posted: June 7th, 2006, 4:16 am
Hi, I have a problem with my idle but only after I engage electrical loads. So I did some measurements which I find strange but can't tell if are worthy:
1. I measured the voltage between battery (-) and the machine head. Well at idle with no loads i saw 50mV. Then I engaged big scale lights, heated glass, ac... and the voltage was 250mV. Is this supposed to happen or I have problems with grounds and/or alternator?
2. I checked for continuity at the two points we short for retreiving codes, set the AAS etc (in the diagnostic plug) and the buzzer was on, indicating continuity. I think this might be a problem!!!
Thanks.
Thanks.
