Noise when I move my steeringwheel.Help needed.
Hi!<P>I have a terrible noise when I turn with my car. It cames when I move my steering wheel. It sounds hole time, still or moving and both when I turn it to right and left. It knorrs, sounds like open an old door. It started with a little noise first but is now embarrasing loud. What can it be?
Angel
Re: Noise when I move my steeringwheel.Help needed.
Check your power steering fluid for low levels or dirty fluid. Check around the resivoir for traces of leaking around the hose outlet. I had this problem and it was easily fixed.<P>------------------<BR>KWK MX3<BR>RED '92 2.5L GSR
KWK MX3
One of my friend told me that it might came from the Suspension also. Check the fluid first, then, if all seem right, check the suspension.<P>Manach
Manach
Ex Mx'er with a Mx-3 1993..
Still in the Mazda Familly with :
-Mazda Rx-7 1987 GXL (Not running, one housing does not compress)
-Mazda Protege MazdaSpeed 2003.5 Titanium!
Still got 3 Engines!
- B6-ZE : Turbo Festiva project (Waiting donor car)
- BP-DE : Trader for a B6-ZE 1994 for parts upgrade in the Festiva project
- K8 : For sell. Pm me for info!
Once you go turbo, you can never go back!
