the gasket that goes between the top and bottom pieces of the intake manifold? or does anyone have the part # for it. thnx
Jon
What the name of that gasket?
- MechaManZero
Intake Plenum Gasket.
Çlark
![Image](http://i64.photobucket.com/albums/h192/Mechamanzero/MX-3/2mx3.jpg)
95 Mazda MX3 4 Banger
Currently: H&R Lowering springs, BPT from a GTR, 18.5x6x3.5 same side inlet and outlet intercooler, Centerforce Dual Friction clutch
For BPT Frorums - http://www.aokforums.com/mazdaengines/
- Custommx3
- Site Administrator
http://www.rockauto.com/catalog/catalog ... ineID=3442
CORTECO Part # 23851
{Intake Manifold Gasket}
**Non-stock item--shipping delayed up to 5 business days** $6.32
thats for a DOHC.
thats for a DOHC.
- atlantamx3
I HIGHLY doubt anyone other than Mazda will have this gasket.
The link you posted, Barry, is for the intake manifold gasket that goes between the cylinder head and the intake manifold.... which is NOT the gasket he is referring to.
On the BP, the intake manifold splits into two pieces--a top and a bottom. The gasket he is referring to is the gasket that goes between the two halves of the intake manifold.
See pic of mine when I had it apart for my first BP swap:
![Image](http://www.atlantamx3.com/BPswap/101004/lowerintakemfold.JPG)
Also, See the Scan I just made of the Shop Manual:
![Image](http://www.atlantamx3.com/BPswap/BPintakeManifolddiagram.jpg)
Why do you need another one? Is your broken? Unless it is damaged, you can re-use it.
