JDM MIATA B6
Bochek
JDM MIATA B6
Post by Bochek »
appairently its 160hp, i have a few questions.... Will it fit?
Why does it have so much more hp then the mx-3 v6's.
What can be improved on the motor for N/A Power?
If you havent figgured it out allready, i just realized that these motors make so much power..... now i want one! more power then a bp and about the same cost.
Bochek
93_4Banger
Post by 93_4Banger »
doubt it will fit because miata is rear wheel drive and the engine is positioned the opposite way so im gunna say no
ariesdude
Post by ariesdude »
I think it can be made to fit if you swap out the oil pan underneath - and probably the exhaust and intake manifolds.
But i remember reading that B6ZE is around 125HP only and BPZE is 160HP - BPZE is the jdm version of BP-DE i think.
94 Mx-3 Precidia
atlantamx3
Post by atlantamx3 »
/\ This is how rumors get started and people become misinformed. /\
The US-Spec BP is called the BP-ZE
Please refer to these sites for future info regarding this question:
http://members.aol.com/solomiata/MX5Engine.html
http://web2.airmail.net/theman/protegefaq/
http://www.imazda.com/forums/showthread.php?t=234
~Perry
Please visit
http://www.mx3-atlanta.com
ariesdude
Post by ariesdude »
I guess i was confused by this website for latest model j-spec miata
http://www.j-garage.com/mazda/roadster/2001.htm
Engine type B6-ZE BP-ZE
Displacement (cc) 1597 1839
Horsepower (PS(kW)/rpm) 125 (92) / 6500 160 (118) / 7000
Those numbers are metric HP which is slightly lower than US HP.
Upon further research i now know that the engine is actually called a BP-Z3 - and its available for 2001 miata roadster. The US version has about 145hp while the j-spec version has close to 155hp.
But it seems no B6 has 160HP in the N/A version. The 90's roadster B6ZE gets upto 120HP.
94 Mx-3 Precidia
Limegreen mx-3
Post by Limegreen mx-3 »
A miata weather its a b6 or BP can be used in fwd form but parts need to changed swap and modififed. i've put a 95 miata bp in a mx-3 so yes it can be done by interchaging parts from the protege bp. and vice versa of the b6 and the mx-3 b6
Limegreen mx-3
93_4Banger wrote:doubt it will fit because miata is rear wheel drive and the engine is positioned the opposite way so im gunna say no
the answer is yes
Bochek
Post by Bochek »
this is where i saw the jspec b6 with 160 hp.
http://www.jdmaddiction.com/mazda.html
Bochek
Cy
Post by Cy »
Anyone who has done a miata BP - to - mx-3 swap should post up because i doubt it's not the same as the protege bp and it's got better flow & valvetrain components(cams)...
atlantamx3
Bochek wrote:this is where i saw the jspec b6 with 160 hp.
Bochek
Well that site also says that the KLZE has 218 HP.... :roll:
Miata motors will fit-- but you have to change out a lot of things from the FWD version and thats just a pain. Why not just get the right motor to begin with?
~Perry
Please visit
Limegreen mx-3
Cy wrote:Anyone who has done a miata BP - to - mx-3 swap should post up because i doubt it's not the same as the protege bp and it's got better flow & valvetrain components(cams)...
I hope this answers ur opioioned doubt.
engine form a miata
same car engine form a fwd protege.
how can u say anything if u never done it ur self i've done it and it can be done and yes converting a rwd bp into a fwd bp is a pain but it can be done.
Limegreen mx-3
Miata motors will fit-- but you have to change out a lot of things from the FWD version and thats just a pain. Why not just get the right motor to begin with?[/quote]
I agree with u but somethings u work with what u can like a spare motor and parts lying around. in my case a maita bp with enough parts to convert it into FWD its not that much too do. but it can be a pain.
Cy
Post by Cy »
i was agreeing that it could be done.. my comment was specific to the Power of the 2 motors.. the Miata has a better head making it a more desirable motor.
WingleBeast
Post by WingleBeast »
how did you do the intake manifold and header?
the IM is pointing the opposite way in the miata
plus the flanges from a miata engine and MX-3 engine are different o you cant jsut swap the header and manifold
Limegreen mx-3
the bolt patterns on the IM and EM and the same regaurdless if its the miata bp or protege bp. as far as what on the pic their custom made for more power. or could just swap the header and manifold as for stock parts
