how much horse power
well, me and my dad just pulled a klde from a mx-6 and i was thinking b4 i put it in my mx-3 i should send my head and stuff to gude, i was wondering what would be a good estamate of hower much hores power should it put out? Like 290hp?
Re: how much horse power
It wouldn't even put out 290 CANADIAN horsepower ..... unless you're going to add a turbo kit.mazda(v6) wrote: Like 290hp?
Think Canadian hp vs american hp like canadian vs american gallons.
Like mentioned, the KLDE makes 164hp and 16tq, but those numbers are at the crank. By the time you get from the crank, through the drivetrain and to the wheels, you'll loose quite a bit of power, usually somewhere around 15% on a manual transmission. I've going for an all N/A setup. From what I've seen, doing as much to the engine/drivetrain as possible, you'll usually get around the bhp (brake hp) value, but in whp (wheel hp). I would expect a max of around 164whp, which would translate to roughtly 189bhp. I haven't done any research in a long time, but when I last did on probetalk, I don't think anyone has broken 200whp on a KLZE, which would be roughly 230bhp.
- PWRD_BY_HKS
ummm.... thats alot of ponies.... but you wont get it all motor ...... well unless ...$$$$$$$$$$....... you know try building it for boost if you cant financial adhere to it nitrous will work too...hey its not the same but tell that to your quarter mile time
jdmx-3 KID OF THE
VICTORIA RACING
ZE PERFORMANCE IN 915 TX
Kl01-ZE,Kl31 ecu, millenia manifold, ngk plugs, ngk wires, probe tranny/ and clutch (stock), VortecH FMU 12:1, Aeromotive AFPR, Tial .38mm Wastegate w/ 4lbs spring, Walboro 255 pump, AiResearch T4, 3" down pipe, GODSPEED manifold, Spearco Boost Gauges, BF Goodrich G-force drag radials.
14.8 1/4 mile all motor untimed on boost.
VICTORIA RACING
Based on that statement i think you might wanan reconsider what your are about to do.mazda(v6) wrote:no not just the porting im talkin bout the whole thing like headers,ecu,porting,ported manifold,ported throttle body,race valves,and new cylinders
If your going all motor you are gonna want to raise compression to somewhere around 10:1 - 11:1. Your gonna want new rods to take the extra stress from spinning the motor higher. Your gonna want more agressive cams. Headwork would be very nice after all that. Ported intake manifold and throttle body. Vales should be ok stock but a valve job should be done with the head work.
In the end your basically building a ZE..... BUT with all the new internals you might put out more hp but not alot more.
And not to be rude but bassed on your origional post you might wanna do a little more research into internal combustion engines. It sounds like you have a basic idea of what you want and how to do it but you might be missing some of the finer points. ie: race valves and new cylinders.
2002 Mazda Protege5 (Turbo kit 75% complete)
1996 Mazda MX-3 Gs KL-ZE
1994 Mazda MX-3 Rs (BP-T?)
