Grinding into R and D
Posted: May 10th, 2006, 4:21 pm
Someone might have already asked this and gotten an answer, but I'm lacking on time and patience right now. But anywho.
I have a 92 MX3 GS. Whenever I shift into Reverse or Drive, there is a bad grinding noise. Maybe its the tranny, but it shifts through the gears fine and goes well forward and reverse. Just replaced the Pass. axle because I cracked the steering knuckle type thing replacing the Ball joint. This noise is brand new. Didn't have it at all until I shifted into reverse in my driveway about a little while ago. Didn't make the noise this mornin when i took off for school, or when I left school for home.
If it needs to be replaced, what trannys can I replace it with, or is the MX3 GS trans. unique. Will the MX6 auto fit, or a 626, 323 or whatever?
