Moisture in altezza tail lights
I've got moisture in my altezza tail lights. I've been reading through some of the posts and some say seal the tail lights and some say drill holes in them, which one works the best and which one should i do? Thanks
if theres moisture in them, then drill holes, i assumme, otherwize seal them to prevent moitsure from getting in.
Bochek
Bochek
- solo_ryder
ooo i so got the answer to this one, put one of thoes silica jell packs that you get in shipping materials.
you know, the ones that are there to absorb moisture.
that should do it.
Bochek
that should do it.
Bochek
Well done Krissy. Unfortunately there wasn't any replys that actually said what to do to help you. Just a lot of guesses. Glad it worked out for you just the same!
* Note for future - "drill hole in bottom". [/quote]
- coolshyguyhere
- BANNED Member
- jschrauwen
True, but if I remember correctly, I don't think the altezza's have the small 90 degree rubber vent tube that's present on the front and rear lights of the OEM units.Joey's mx wrote:drill holes...did you ever notice stock headlights and taillights have breather holes in them?? They are there so the lights can breathe!! air has to be able to get in between the lens!!
Now that all of the moisture is out, I would recommend that you try a complete sealing around the altezza's. I used a silicone on a very hot day and just let it wick it's way around the seam by slowmly rotatiing and adding new silicone as you go. A bit of a tediuos process, but once done you should never see any more fogging issues. I did mine last summer outside during one of our hotter days and it helped greatly to keep the silicone in a more fluid state to get it to flow all around the seam. If the drilled holes and the seam is not resealed I think you may still encounter more fogging. But you can always test that theory next time at the car wash.KrissyKCMU wrote:It worked good for me, it took a few days though for it to completely clear up. If they were really bad, like mine, and you wanted quicker results, I used a hairdryer where I drilled the holes.
maybe the car washes north of the border have weaker water pressue or something, but i could NOT get a good seal for the life of me with silicone, with two sets of altezazas. i drilled some holes across the bottom too and have not seen a hint of fog for months now, which is completely unprecedented.
i will have to snap some pictures, but i drilled holes across the bottom, on the black backing part, not the clear lens, so it's well away from being exposed.
Its actually logical - because sealing them would just trap the atmospheric humidity inside the lights and they would fog up again and again - drilling holes is like opening the window a tiny bit on a rainy day to get rid of windshield fog.ninjajim4 wrote:i drilled some holes across the bottom too and have not seen a hint of fog for months now, which is completely unprecedented.
94 Mx-3 Precidia
