Leak in front far left part of cars cabin
The new GS i picked up a few months ago has had a huge problem with water pooling on the driver side floor board.... i am not sure where exactly it is coming from.... it seems to be on the extreme left side near the front.... could there be a problem with the dain from the sunroof? or is it likely a leak in the windshield? and how can i find out?
ProjectMx
My BP and AWD build thread
Cardomain
93 Escort GT daily driving
Cardomain
pull your headliner off its probably a leak hose from the sunroof draining tubes
could be a leak from the heater controls...
-hec
the first thing that came to my mind was heater core, but now that i think about it, i think its on the passenger side of the car.hgallegos915 wrote:could be a leak from the heater controls...
Bochek
any suggestions on how exactly to locate the leak? i have the interior almost completely gutted going to try and get the dash out this weekend so i would assume it shouldn't be too hard to find the leak once everything is out...
ProjectMx
Cardomain
Cardomain
- relisys_3200
why would i be looking on the right hand side for a leak on the left hand side? and it appears the sunroof has hoses going to several areas not just the front left but it has one for sure going to the front left and could end up behind the fuse box so i'll try and get back there to look this weekend
ProjectMx
Cardomain
Cardomain
if they had one you would have some water stuck in the sunroof and rust power would emerge.
-hec
i think i found it the hose seemed to have complete come out and was facing inside of the cabin of the car so i felt around and i think i put it back where it belongs... we'll see
ProjectMx
Cardomain
Cardomain
