I am in need of steel headgaskets for my 2.5, I want to order them asap so I can get to the track this weekend and spray my way into the 13's.
I also need an adjustable fuel pressure regulator and a cheap air fuel gauge.
let me know!!
where can I get these parts?
- stereoking15
you can check out importperformanceparts.net and they should have one but it's some real $$$ and also i am having real difficulties getting my set up with my adjustable fuel pressure regulator to wrok just because of the fuel rail adapter i got one from weapon r and said i needed the smaller one and sent me the larger have not had time to send back but if you go to get one specify the smaller ended one
